Message |
AceZX, Before you change that seal, check the two PCV valves. If they are clogged the crankcase pressure will push oil out the rear engine seal. Ten years ago or more I had the same issue, but it was a minor leak, leaving a pop can diameter puddle on the garage floor after each drive. I changed both PCV valves and the leak has not returned. That was at about the 50 000 km/ 30 000 mile mark, and the car has about 88 000 km/ 53 000 miles today.
